I am looking for a way to create mac based vlan on hap ac3. All examples which I was able to find were meant for CRS model and assumes to configure it on switch level (/interface/ethernet/switch/mac-based-vlan). I don’t see that option in hap ac3. Is there any way to configure this feature on this model?
I am getting back to this matter again as I needed to postpone it for some time.
Thanks for the comments on this topic. Based on them - I am assuming that the option I should use is “new-vlan-id” from Switch → Rule menu. Unfortunately, this option is not supported by Atheros 8327. Did you have in your mind a different option that should be used?
