I want to move devices with specific MAC addresses to a dedicated VLAN.
If device with MAC address DC:2C:6E:AE:05:3B is plugged into CRS326, it should get VLAN ID 155.
This should work with any port from the CRS326 devices.
There are multiple CRS326 devices and each has a IP address within VLAN ID 155.
The VLAN setup is already working and each CRS326 can ping the IP adddress from each VLAN ID 155.
If i understood the MK help correctly, i can do a MAC based VLAN with a switch rule.
Since this setup should work with any ethernet port, does for the option “ports” the value “switch1 cpu” would work, or do i have to add all physical ports to the switch rule?
Do i need to add all ports as tagged member for the Bridge VLAN ID 155, or is it then untagged?
Regards,
Cynrik
