mac cookies
I am running router os with 2 hotspots on it different IP ranges folders and vlans. If I have mac cookie turned on then it allows you to login toone hotspot and then switch over to the other without having to login. Is there anything simple I am missing?
NO i don’t think so, but what exactly problem you are facing?
