MAC<->IP association
I used to set some ACLs on CRS226 cloud switches, which allowed me to restrict access so that only a given IP and a given MAC could make traffic on a given switch port. It worked perfectly and was very easy to setup (https://wiki.mikrotik.com/wiki/Manual:CRS_features#ACL)
Unfortunately the CRS226 is going out of production and the replacement seems to be the CRS326 which is missing this feature from the RouterOS side. I also tried on CRS125 but the feature is completely missing on this model.
I tried to make a similar setup on a CRS326/SwOS but it doesn’t do quite well. ACLs seems to work for a few seconds, then it behaves unpredictably. I tested and re-tested for days, always same results. It isn’t feasible for production environment.
Can you suggest me a working solution?
Thank you very much!
If CRS326 ACLs aren’t working, you’d better write support (make sure you’re using latest SwOS, 2.4)
