Mac os X dropping WiFi
Hi guys,
I have little problemregarding WAP AP. I have it at gome connected on cable router serving as AP. My Windows clients work ok, but 2 Macbook Pros keep disconnecting and connecting all over again. For test I connected UniFi and connected them to it to rule out Macbooks but they work great on it. I susspect there has to be something with config since, but I cannot find anything wrong with it.
Here is my config:
# feb/14/2018 09:21:44 by RouterOS 6.40.5
# software id = 1VD1-Q5H4
# model = RouterBOARD wAP 2nD r2
# serial number = 676605CBB2C0
add fast-forward=no name=AP_Bridge
set [ find default-name=ether1 ] name=ether1-gateway
add authentication-types=wpa-psk,wpa2-psk eap-methods="" group-ciphers=\
    tkip,aes-ccm management-protection=allowed mode=dynamic-keys name=\
    lostinuniverse supplicant-identity="" unicast-ciphers=tkip,aes-ccm \
    wpa-pre-shared-key=xxxxxxxxx wpa2-pre-shared-key=xxxxxxxx
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-eC \
    disabled=no distance=indoors frequency=auto mode=ap-bridge name=\
    wlan1-local security-profile=lostinuniverse ssid="xxxxxxx" \
    wireless-protocol=802.11
/ip hotspot profile
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc
# DHCP server can not run on slave interface!
add address-pool=default-dhcp authoritative=after-2sec-delay disabled=no \
    interface=wlan1-local name=default
/system logging action
set 1 disk-file-name=log
add bridge=AP_Bridge interface=wlan1-local
add bridge=AP_Bridge interface=ether1-gateway
add address=192.168.0.2/24 interface=AP_Bridge network=192.168.0.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=\
    no interface=ether1-gateway
add address=192.168.88.0/24 comment="default configuration" gateway=\
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
# in/out-interface matcher not possible when interface (ether1-gateway) is slave - use master instead (AP_Bridge)
add action=masquerade chain=srcnat comment="default configuration" \
    out-interface=ether1-gateway
/ip smb shares
set [ find default=yes ] directory=/pub
/system clock
set time-zone-name=Europe/Zagreb
/tool bandwidth-server
set authenticate=no
… or Apple is not compatible with Mikrotik. but for now I don’t belive it :astonished:
