Hi everyone. I hope you can help me
I have a pvid configured on my ethernet port because I need to tag all incoming traffic. VLAN filtering is enabled
The problem is that I need to access via mac-telnet the neighbors of my mikrotik (they are connected directly through a cable) but I can’t access because the pvid is configured.
The traffic is untagged when leaving.
I’m sure the pvid is the problem because in other setups I have ports on a bridge (VLAN filtering=yes) without pvid and I can access other neighbors via mac-telnet.
Here’s the config (it’s very basic):
add name=bridge1 vlan-filtering=yes
set [ find default-name=ether1 ] name=ether1_to_DHCP_Server
set [ find default-name=ether2 ] name=ether2_to_end_device
add bridge=bridge1 interface=ether1_to_DHCP_Server
add bridge=bridge1 interface=ether2_to_end_device pvid=10
/interface bridge vlan
add bridge=bridge1 tagged=ether1_to_DHCP_Server untagged=ether2_to_end_device
vlan-ids=10
Does anyone know how to fix this? Is there an option within the bridge menu that needs to be activated to fix this?
