MAC Telnet
Im trying to create the cleanest configuration possible and learn how to efficiently load my routerboards in a disaster recovery situation. I run a network that is a spoke hub vpn. all of the spokes are the same 2011 wifi models and I have been cutting and pasting the config on the fly from a functioning unit to a replacement unit doing find/replace on all of the names and subnet entries that differentiates one remote location from the other. this way of doing things has led to slower response time on my part as errors are made or key entries are missed.
that all said…
My personal laptop is a mac that i use parallels to run windows. winbox works well and so does the “winbox for mac” as long as there is an IP address. my goal here is to start with a blank router so i can “set” values and not be changing an existing configuration. so i need to mac telnet into the unit after wiping the default config. neither parallels nor “winbox for mac” can establish a mac telnet session for more than a few seconds before it drops. my next option was to hook the blank router up to my “CORE” router, winbox into that and then MAC telnet to the unit.
here I ran into an issue I have also seen “in the field” with routerboards. the default config does not have a password and neither SSH or Mac telnet (nor i assume telnet) will allow you to login without a password. it simply disconnects after I type admin and then blank for the password
Who has a solution for my issue?
My ultimate goals would be to either…
  1. replace the default image with my own so a “reset configuration” would bring back to MY stock image
  2. create some sort of install script where I answer the subnet value and the location name value and the configuration loads the proper info in the proper part of the config
  3. (and most likely) I will make a “base image” on an unused subnet. in the field one of my less experianced techs could easily load the “base backup image”. once that is done I can get to the remote tik from my “core” (we use dynamic ips) with my own default passwords and I would know exactly what needed changing (better than currently)
anyway if anybody has some best common practices (and I dont want to hear get a windows machine :wink: ) Id really appreciate hearing them.
Option 1 works via flashfig.
Telnet and mac telnet are available from the clear reset without restriction.
For 3.
A. Export such minimal configuration to script.
B. Replace data to tailor with some “macros/identifiers” easy to find e.g. <>
C. Make some script which asks for Identity, MACs etc. data for the new router and replaces proper “macros” with new values
D. Import such script to the new device.
or …
Look at https://wiki.mikrotik.com/wiki/Manual:TR069-client
Thank you both for your answers. I will begin researching both flashfig and creating the script
about the MAC telnet here is the output I get..
[thor@OfficeCore] > /tool mac-telnet host=D4:CA:6D:E5:FD:02
Login: admin
Password:
Trying D4:CA:6D:E5:FD:02…
Welcome back!
[thor@OfficeCore] >
This is a router I reset to default config, connected via winbox, chose to clear the config, connection drops due to lack of IP, only option now is to MAC telnet
I connected the reset router directly to my “core” router and have tried both ssh to core and using winbox to core and launching a terminal within winbox.
anybody know for sure that admin with no password on a reset blank mikrotik should work for sure?
It definitely should. Just make sure you removed the config and were not keeping the users…
I have marked that particular router as damaged and removed it from my inventory. I tried the same procedure with another unit and had no problem MAC telnetting to it after a full config wipe.
Have you tried to repair it by netinstall?
