I saw somewhere script that does lookup logs for ipsec errors to block undesired connection attempts. You can try and do the same - make a script that looks up for whatever you want, extract MAC from the message, look for dhcp-lease with corresponding MAC, :log info $MAC . $AP with the format you want.
Since what you want is not a common request, I doubt this would be implemented, but with some effort you can make it on your own.
