well Im still not shure can I block encrypted p2p as well.
macgavier our frined
, written a fw rule that should block all p2p connections and I copied that rule into my MT box, To some point I can see the difference, I can surf the web
, and I couldnt do that before
, but I still can see p2p established connections in connection tracking?? is this normal??
@ MikroTik team
please if you want to get rid of us p2p annoyers
, please install torrent software and figure out how to drop it, because I cant fid the way to block it.
Wow, I am popular ![]()
Those rules was not ideal - that was best you can do by only adding several rules for p2p detection!
Only other way is to mark all necessary traffic and prioritize it before other traffic (including p2p). And it is lot of work and lot of time to adjust your rules for all traffic types
And then use QoS like I described here:
and - where you did add these rules?
if after accepting established connections - sure they will NOT be dropped, you have to ensure that ll p2p connections are made AFTER you add rules.
any new connections should not be established.
and yes, macgaivers suggestions about QoS is good one ![]()
