macOS - how to connect to VPN
Hello!
I have a “VPN Access” option enabled in my Mikrotik RB hAP and password set. How to connect to VPN using macOS workstation?
Cheers
When you activate the VPN via the QuickSet option
It will enable and setup SSTP, L2TP and PPTP
L2TP is your best choise for MacOS
All the information you need is shown in the Quick-Set menu,
What VPN client is recommended for macOS? Can you please elaborate how to configure this client?
I don’t own any MAC-Computers…
So i can’t really help…
If i understand the VPN-Guide from Apple you don’t need to Install any VPN-Client.
https://support.apple.com/guide/mac-help/set-up-a-vpn-connection-on-mac-mchlp2963/mac
