ssh displays really funky on my MacBook Pro.. its really unusable it will only show one line after connecting…
SSH Client: OpenSSH_4.5p1, OpenSSL 0.9.7l 28 Sep 2006
Works fine with Putty from a windows client…
You should try glterm instead of the apple terminal program. Much nicer. If you insist on using the apple one, it’s probably a emulation setting which can be set via environmental variables, or perhaps in the program’s menus.
after you have connected, resize the terminal window (slightly bigger). it will start working then. it looks like a macos leopard issue.
Yup that works.. I can live with that. ![]()
