made function from dhcp server total user lease
hello again folks.. wish you all good and healthy…
lets to the point
command that working (and repeatly stated):
:global leaseServer1 "dhcpd.120.254/25";
:global leasetotal1 [/ip dhcp-server lease print active count-only where server=$leaseServer1];
how to made that correctly into function because this code below not working:
:global FNleasetotal1 do={:global leaseServer1;\
			:ip dhcp-server lease print active count-only where server=$leaseServer1;\
and store the result to new variable seems not right ( no result or empty)
:global leasetotal2 ($FNleasetotal1);
best regards,
FNleasetotal1 do not :return nothing…
:trying :return still return wrong result. ( :put [$function] )
how the proper way or solution ? (or this couldnt make into function?)
best regards,
still not return nothing, also with useless :put [$function] (which means nothing written so randomly).
this function code works:
running in script
:local leaseServer1 "dhcpd.120.254/25";
:local FNleasetotal1 do=[/ip dhcp-server lease print active count-only where server=$leaseServer1];
$FNleasetotal1
best regards,
