Main factors affecting on CCQ
Hello
can you tell me what are the main factors affecting on the CCQ
is it the signal strength ? or the noise ? or what?
will the drop of CCQ cause disconnection
thanx in advance :slight_smile:
Noise, overloaded AP, hidden node, client seeding torrents at high bandwidth, incorrect ack timeout settings. Basically every thing
And algin algin algin algin :slight_smile: At least for p2p
align …
… algin is a chemical taken from brown seaweeds. It is used to make medicine. :wink: …
:stuck_out_tongue: Align,adjust,set or something like that. :smiley:
