After running Userman on a RouterOS PC for a log time and having problem when there was a power failure to recover the database.
I decided to build a Maintenance Script to backup Userman’s database and make a export file and a system backup and then to FTP the files to my ftp server. This Script is base on what I got from read the MikroTik Forum and a lot of testing.
I have to create four scripts, one for disabling users in Userman not to be able to connect to Userman, will the maintenance is done at 01:00:00, the second one for disabling all Active Connections for all users at 01:00:01 hrs, The third scripts is where I backup all the necessary files and then it get FTP to my FTP server and then it get remove form my system at 01:00:02 you can schedule them as per your required timings. The Forth script enables all the user on Userman to reconnect if there session is active at 01:04:00. Check how long your the Userman-Backup-Export-FTP script runs and set your Forth script time according to how log it takes to run.
1st Script name: Disable_Users_For_Maintenance_Userman
# Setting Clock Time
:local CurrentTime [/system clock get time];
:log warning "Disabling Users for Userman at Current Time = $CurrentTime."
# Setting Variables for Disabling Users in Userman
:local Flag
:set Flag [/tool user-manager user find]
:if ([:len $Flag] > 0) do={/tool user-manager user disable [/tool user-manager user find];}
# Log
:log warning "Disabling Users for Userman Completed . . ."
2nd Script name: Disable_Users_For_Active_Connections
:log warning "Disabling Users For Active Connections at Current Time = $CurrentTime"
# Setting Global Variables - Disabling Active Connections
:local Flag
:set Flag [/ppp active find]
:if ([:len $Flag] > 0) do={/ppp active remove [/ppp active find];}
# Log
:log warning "Disabling Users For Active Connections Completed . . ."
3rd Script name: Userman-Backup-Export-FTP
# Automated Userman backup & Export & RB Backup then FTP to External FTP site
# File name:Userman-Backup-Export-FTP
# Get identity
:local thisbox [/system identity get name]
# Get time
:local thistime [/system clock get time]
:set thistime ([:pick $thistime 0 2].[:pick $thistime 3 5].[:pick $thistime 6 8])
# Get Date
:local thisdate [/system clock get date];
:local month
:set month [:pick $thisdate 0 3]
:if ($month="jan") do { :set month "01"}
:if ($month="feb") do { :set month "02"}
:if ($month="mar") do { :set month "03"}
:if ($month="apr") do { :set month "04"}
:if ($month="may") do { :set month "05"}
:if ($month="jun") do { :set month "06"}
:if ($month="jul") do { :set month "07"}
:if ($month="aug") do { :set month "08"}
:if ($month="sep") do { :set month "09"}
:if ($month="oct") do { :set month "10"}
:if ($month="nov") do { :set month "11"}
:if ($month="dec") do { :set month "12"}
:set thisdate ([:pick $thisdate 7 11]."_".$month."_".[:pick $thisdate 4 6])
# Export file name will be Export_RB Identity_Date_Time .rsc
:local FExport ("/Export_".$thisbox."_".$thisdate."_".$thistime.".rsc")
:delay 10s;
/export file=$FExport
# System backup file name will be BackUp_ - RB Identity - Date - Time .backup
:local FBackup ("/BackUp_".$thisbox."_".$thisdate."_".$thistime.".backup")
:delay 10s;
/system backup save name=$FBackup;
# This Userman backup file name will be Userman_ - RB Identity - Date - Time .umb
:local FName ("/Userman_".$thisbox."_".$thisdate."_".$thistime.".umb")
:delay 10s;
/tool user-manager database save name=$FName
:delay 10s;
:log info message="Backup File's is Create - $FBackup";
:log info "Backup File's is Create - $FBackup";
:log info "Export File's is Create - $FExport";
:log info "UM Database Backup File is Create - $FName";
:delay 10s;
:log info "Export File & System Backup & Userman Backup File's is now been send to your FTP Server";
# Upload the Export file to your FTP server - change address to your ftp server + user + pass + upload_path
/tool fetch address="192.168.0.48" user="mikrotik" password="mikrotik" mode=ftp src-path="$FExport" dst-path="/$FExport" upload=yes
:delay 40s;
# Upload the System Backup file to your FTP server - change address to your ftp server + user + pass+upload_path
/tool fetch address="192.168.0.48" user="mikrotik" password="mikrotik" mode=ftp src-path="$FBackup" dst-path="/$FBackup" upload=yes
:delay 40s
# Upload the Userman backup file to your FTP server - change address to your ftp server + user + pass+upload_path
/tool fetch address="192.168.0.48" user="mikrotik" password="mikrotik" mode=ftp src-path="$FName" dst-path="/$FName" upload=yes
:log info message="Export File & System Backup & Userman Backup File's is now done sending to your FTP Server";
:delay 5s;
# Removing files from system
:foreach i in=[/file find] do={:if ([:typeof [:find [/file get $i name] "Export_"]]!="nil") do={/file remove $i}}
:log info message="Export File's is removed";
:foreach i in=[/file find] do={:if ([:typeof [:find [/file get $i name] "Userman_"]]!="nil") do={/file remove $i}}
:log info message="Userman Database Backup File's is removed...";
:foreach i in=[/file find] do={:if ([:typeof [:find [/file get $i name] "BackUp_"]]!="nil") do={/file remove $i}}
:log info message="Backup File's is removed";
4th Script name: Enable_Users_For_Userman
:log warning "Enable Users For Userman at Current Time = $CurrentTime"
# Setting Global Variables- Enabling Users in Userman
:local Flag
:if ([:len $Flag] > 0) do={/tool user-manager user enable [/tool user-manager user find];}
:log warning "Enable Users For Userman Completed . . ."
Scheduler Entry to run all the scripts at given timings.
/system scheduler
add interval=1d name=Disable_Users_For_Maintenance_Userman_at_01:00:00 on-event=Disable_Users_For_Maintenance_Userman \
policy=ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive,api \
start-date=Mar/18/2014 start-time=01:00:00
add interval=1d name=Disable_Users_For_Active_Connections_at_01:00:01 on-event=Disable_Users_For_Active_Connections policy=\
start-date=Mar/18/2014 start-time=01:00:01
add interval=1d name=Userman-Backup-Export-FTP_at_01:00:02 on-event=Userman-Backup-Export-FTP policy=\
start-date=Mar/18/2014 start-time=01:00:02
add interval=1d name=Enable_Users_For_Userman_at_01:04:00 on-event=Enable_Users_For_Userman policy=\
start-date=Mar/18/2014 start-time=01:04:00
If you can enhance this scripts please do so, you can modify it as you like.
Please give karma if the post helps you, Thx.
