Major Major Feature Request..
User and Group Permissions on a per Map Basis..
I.E
View-Status of Map
View-Read Map
View-Admin Map
This would be so cool and make my life a dream..
Keep up the great work.
Lee
Please, be more specific what you mean by
Quite simple..
So I can create a group for a customer under Admins, that for example only has access to certain maps, thus not showing all the other maps.
I envisage being able to have maybe a permission tab on the Map Setting or have the ability to add maps to the group with the cascading arrows..
In each meathod have three options
Status View - This enable to see red orange green for a submap
Read View - The ability to view the Map
Read Write View - The ability to make changes to the map
Also it would be good to be able to overwrite the default user/pass for the node device within the admin/login accout.
Does this help??
Lee
udis ??
what about making users to be able to access only certain panels with either read only or read/write permissions
This could work…
How would I then restrict access to other maps in the application, or the outage section… Etc
The idea is to use it in a managed provider manor, so hence the customer can see his/her infastructure but nobody elses, while I can install a seperate dude for each customer I don’t really want to do this as there is no easy way to report the status of these dudes on one central dude yet..
Lee
Udis ???
Any further info on this as we have a pressing application to use the Dude in such a way..
Regards
Lee
we have added this to our TODO
Hi all,
I’ve got another suggestion/request.
I think it would be a great feature if it would be possible to access the graphs of the selected device also from the Webserver-interface. This would be convenient for other people to see what’s happening without the need to install the Dude on a PC or so.
Might be an idea for a future release if you ask me.
Regards,
Minollie
