Major problems with webproxy!
I was use webproxy on 2.9.x version and works fine.
last week i need to setup new cache with ROS 3.13 and
have several problems.
I was setup with IDE-Flash as system drive and 40Gb IDE-HDD as cache drive.
first of all i was type “format-drive primary-master” and then yes
and get “drive will formatted shortly” and noting happens (No HDD LED blinking and so on)
and then i was type “set cache-drive=primary-master”
and get “format the disk befor using it for cache”
i was done this several times and nothing happens.
has any one test this before and has any suggestion.
Regards
Ali
We confirmed that described behaviour is a bug, it’will be fixed at 3.14 version.
AOA
brother y r you not using external cache server
i think is 50% better then internal caching, fast browsing fast resolving and using low system sources
Allah hafiz
I had the same problem. I simply disabled web-proxy in Mikrotik and added IPCOP in another PC between WAN and Mikrotik.
That did the trick, till 3.14 arrives…
AOA
http://wiki.mikrotik.com/wiki/How_to_use_external_open_source_caching_server
so simple
When does version 3.14 became avaible?
hopefully next week ?
Dear Brother Muhammad,
Salam, I have few questions for you. 1st of all can you give squid setting, I mean your squid.conf file setting. are you using TOS in the both squid and MT?
And BTW what is AOA :slight_smile:
H Zahid
