Make ddm work for Sfp
Hello
Plese make these things(check attached image) visible on Supported SFP like my other Switches are showing
Many RouterBOARD models support DDMI. Which model are you talking about specifically?
RB2011
RB260GS
these support ddm but real info are not shown :frowning:
What ROS? Have you instaled 6.15?
yes 6.15
amazing no reply till now??
Normis , uldis Please tell when this will be implemented
it’s hard to monitor link status without the features.
Wake up guys
do something
this is a mostly customer forum, so to get quick and reliable answers, you should consider to send an email to support@mikrotik.com :wink:
And please, post also here, if you get new informations.
HTH,
Ronny
there should be Tx/Rx signal power fields available. Maybe you can give us remote
access to this device so we could check the problem or send us screenshot of it?
Regards,
Krisjanis
i sent the screen shot then got this reply
indeed, thank you for screenshots. It is now reported as a bug to our developers.
Regards,
Krisjanis
I did receive a quick answer from our developer which maintains SwOS. And
unfortunately this ddmi info part wasn’t included in SFP as it was causing a bit
to high load on switch hardware. Therefore it was decided not to support it in SwOS.
Regards,
Krisjanis
This feature won’t be supported only in SwOS devices: RB260GS and RB260GSP. In
RouterOS devices it should work if module supports reporting this info.
Regards,
Krisjanis
i guess buying a cheap media converter is better than this switch after all without DDMI the SFP is just like a simple media converter
