Make Hotspot Usernames for different APs
Hi, I really need some help, thanksss
please see my below map first,
Internet → Mikrotik → Cisco Managed Switch (port 10) to → CISCO Un-Managed Switch 24 ports → for 24 LANs (PCs)
(port 1) to → AP (Access Point) 1 → 20 users
(port 2) to → AP (Access Point) 2 → 20 users
(port 3) to → AP (Access Point) 3 → 20 users
Now, I have created Hotspot Usernames for all 24+20+20+20 already
eg. 24 Hotspot Usernames for “LANs (PCs)” → eg. “user1, user2, user3…user4” Usernames for this GROUP
20 Hotspot Usernames for “AP 1” → eg. “ap1_aaa, ap1_bbb, ap1_ccc…ap1_ttt” Usernames for this GROUP
20 Hotspot Usernames for “AP 2” → eg. “ap2_aaa, ap2_bbb, ap2_ccc…ap2_ttt” Usernames for this GROUP
20 Hotspot Usernames for “AP 3” → eg. “ap3_aaa, ap3_bbb, ap3_ccc…ap3_ttt” Usernames for this GROUP
However, I need Username works ONLY for EACH group, NOT for ALL group
eg. -if I use “user3” Username log in via “LAN”, it works!!, but it MUST not work when log in via AP 1, AP 2, AP 3
-if I use “ap3” Username log in via “AP 3”, it works!!, but it MUST not work when log in via LAN, AP 1, AP 2
-if I use “ap1” Username log in via “AP 1”, it works!!, but it MUST not work when log in via LAN, AP 2, AP 3
How can I achieve that effect, I’m really new to this.
Please help me out, thank you so much in advanced !!!
I think you can achieve this through address pool assignment on hotspot server and user profiles.
If ap3_user connects to ap3; will get only an IP from specified pool from the ap3_dhcp server.
If ap3_user connects to ap2; then ap3_dhcp will give IP from ap3 pool to user ap3,
you block/reject/control ap3_user/ap3_pool on ap2
Thank you for the reply,
I got for what you mean, about setting separate address pool assignment for each hotspot server & user profiles,
However, how can I specify ap1, ap2, ap3?
do i need to specify “VLAN” or something?
I mean how can I tell Mikrotik to know that, because as you can see my map in my 1st post,
Internet that come out of Mikrotik got only 1 LAN connect to CISCO Managed Switch.
so, there are 4 Lans connect to 1)Unmanaged Switch, 2)AP1 3)AP2 4)AP3.
is it possible to assign MAC Address for those APs?
because all the connected device (MAC Addresses) I see in Mikrotik, ONLY show the connected device that connect FROM APs, not APs themself.
I mean, MIkrotik sees only MAC Addresses of connected devices, NOT the MAC Addresses of those 3 APs
Please help me further, thank you so much!!
You will need to put the LAN and all 3 AP’s on separate VLAN’s. Then create a Hotspot Server for each VLAN. Then on each Username, you can specify which Server that Username is for.
