"Make static ip" turns off internet access, LAN is ok
Hi
I have this strange behavior. If I turn a DHCP ip into a static ip as 10.0.1.90 in Winbox UI, the internet is turned off. Internal LAN is working fine.
If I have the client itself registering with same static ip, it works just fine.
Client is connected at ETH4 with ip 10.0.1.90
Can anyone tell me what is the problem ? Thank you
# 2025-04-17 07:08:29 by RouterOS 7.18.2
# software id = CNF3-TWQL
# model = RBD53iG-5HacD2HnD
# serial number = D96B0CE99878
add admin-mac=48:8F:5A:9F:12:22 auto-mac=no comment=defconf name=bridge
add name=bridge-vlan10
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n channel-width=20/40mhz-Ce \
    country="united states" disabled=no distance=indoors frequency=2437 mode=\
    ap-bridge name=2.4G ssid=io wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-onlyac channel-width=\
    20/40/80mhz-Ceee country="united states" disabled=no distance=indoors \
    mode=ap-bridge name=5G ssid=io5 wireless-protocol=802.11 wps-mode=\
    disabled
/interface vlan
add interface=bridge-vlan10 name=vlan10 vlan-id=10
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik
add authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys name=profile \
/interface wireless
add disabled=no mac-address=4A:8F:5A:9F:12:27 master-interface=5G name=wlan3 \
    security-profile=profile ssid=iog vlan-id=10 vlan-mode=use-tag
add disabled=no mac-address=4A:8F:5A:9F:12:26 master-interface=2.4G name=\
    wlan4 security-profile=profile ssid=iog vlan-id=10 vlan-mode=use-tag
add disabled=no keepalive-frames=disabled mac-address=4A:8F:5A:9F:12:28 \
    master-interface=2.4G multicast-buffering=disabled name=wlan_iot \
    security-profile=profile ssid=iot vlan-id=20 vlan-mode=use-tag \
    wds-cost-range=0 wds-default-cost=1 wps-mode=disabled
/interface vlan
add interface=wlan_iot name=vlan20 vlan-id=20
add name=dhcp ranges=10.0.1.100-10.0.1.254
add name=dhcp_pool1 ranges=10.0.10.100-10.0.10.254
add name=dhcp_pool2 ranges=10.0.20.100-10.0.20.254
add address-pool=dhcp interface=bridge name=defconf
add address-pool=dhcp_pool1 interface=vlan10 name=dhcp1
add address-pool=dhcp_pool2 interface=vlan20 name=dhcp2
/queue simple
add max-limit=10M/120M name=120M queue=\
    pcq-upload-default/pcq-download-default target=10.0.1.0/24
add max-limit=2M/10M name=guest queue=pcq-upload-default/pcq-download-default \
    target=10.0.10.0/24
add max-limit=10M/20M name=iot queue=pcq-upload-default/pcq-download-default \
    target=10.0.20.0/24
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
/interface bridge filter
add action=drop chain=forward in-interface=wlan3
add action=drop chain=forward out-interface=wlan3
add action=drop chain=forward in-interface=wlan4
add action=drop chain=forward out-interface=wlan4
add bridge=bridge comment=defconf interface=2.4G
add bridge=bridge comment=defconf interface=5G
add bridge=bridge-vlan10 interface=wlan3
add bridge=bridge-vlan10 interface=wlan4
add interface=vlan10 list=WAN
add interface=vlan20 list=WAN
add address=10.0.1.1/24 comment=defconf interface=bridge network=10.0.1.0
add address=10.0.10.1/24 interface=vlan10 network=10.0.10.0
add address=10.0.20.1/24 interface=vlan20 network=10.0.20.0
/ip arp
add address=10.0.1.90 interface=bridge mac-address=00:01:2E:64:F0:65
/ip dhcp-client
/ip dhcp-server lease
add address=10.0.1.90 client-id=\
    ff:d:96:8f:69:0:2:0:0:ab:11:5a:d1:3d:66:9e:70:26:c8 disabled=yes \
    mac-address=00:01:2E:64:F0:66 server=defconf
add address=10.0.1.0/24 comment=defconf dns-server=8.8.8.8,1.1.1.1 gateway=\
    10.0.1.1 netmask=24
add address=10.0.10.0/24 dns-server=1.1.1.1,8.8.8.8 gateway=10.0.10.1
add address=10.0.20.0/24 dns-server=1.1.1.1,8.8.8.8 gateway=10.0.20.1
set allow-remote-requests=yes
/ip dns static
add address=10.0.1.1 comment=defconf name=router.lan type=A
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=established,related disabled=yes hw-offload=yes
    connection-state=invalid
add action=masquerade chain=srcnat out-interface-list=WAN src-address=\
    10.0.1.90
/ip kid-control
add name=kid1
/ip smb shares
set [ find default=yes ] directory=flash/pub
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
    dst-port=33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=America/Detroit
/system note
set show-at-login=no
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys \
    policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    source="\r\
    \n   :if ([system leds settings get all-leds-off] = \"never\") do={\r\
    \n     /system leds settings set all-leds-off=immediate \r\
    \n   } else={\r\
    \n     /system leds settings set all-leds-off=never \r\
    \n   }\r\
    \n "
/tool mac-server
/tool mac-server mac-winbox
Post the output of:
/ip address print
and of:
/ip route print
Two of them, once when you have the DHCP client normally running (and everything is working) and once when you try assigning a static IP (and internet connection is lost).
Are you assigning in Winbox the IP address 10.0.1.90 or the IP address 10.0.1.90/24?
The MAC address in the static DHCP lease is wrong, should be 00:01:2E:64:F0:65 instead of 00:01:2E:64:F0:66.
Edit that entry, clear Client ID (by pressing the triangle button) and change the MAC address to 00:01:2E:64:F0:65.
