Make tool, copy to all computers, possible?
and then apply it to all machines, is there an easy way to do this?
-Michael
copy what exactly?
Sorry, you’re right that wasn’t very specific. So, on the local map you can right click on a computer, go to settings, then the tools tab, then I hit the plus to add a tool. In my case its for UltraVNC then I hit OK. Well now I have that tool for that computer but I want the VNC tool to be able to be used on all of the computers!
“Contents” menu on the left side.
The second line is “Tools” dubleclick.
Red Plus, then add the tool.
Now you created a tool globaly for all the devices…
OR:
“Contents” menu again, select Devices. Then Select Types tab. You can create a custom device type (computers), the double click it. There will be a tool tab, where you can specifi custom tools for these device types. Now you have only to do: change the computer’s types (on the device) to computers.
I hope this helped
Yes, thanks a bunch! That does the trick!
