Hello!
What is the size(mm) inside and outside of male power plug for routers… Or all routers fit the same size?
EDIT: RouterBoard will fit 2.1 mm male power plug?
Thank you
Hello!
Thank you
5.5mm outside and 2mm inside diameter, female, pin positive plug, accepts 8-30V DC
All RouterBoards are the same size?
Thank you
yes
Thank you
