i have rb951Ui-Hnd and on the security profiles i confuguring protection frames to required and i enter the frame protection key , Now the question is , the client is windows 10 laptop and i check on the command prompt with this command “netsh wlan show all” it’s a command to show my wireless card capability and it said managament protection frames is supported , but how to connect client laptop on the network that required frame protection key
