Management frame protection
Will wireless management frame protection setting work when using NV2 protocol?
I dont think so, since nv2 dont use the Wireless Security. Nv2 use the Secret in /Interface Wireless setting.
Edit: Or maybe. if using key in Access list. :stuck_out_tongue: Im unsure like you.
I have the same opinion that management frame protection will not operate when using NV2 protocol, I wish as I mentioned way back… That Mikrotik would simply grey out functions not operational when different wireless protocols are used?
Hmm… Thanks for the update.
