Management Interface on VLAN aware Bridge + bonding interface as tagged port
Good day anyone can lay a hand as to why I can’t create a management interface on a VLAN aware bridge if the port member of the bridge is a bonded interface and will be used as a tagged port.
test.rsc (921 Bytes)
The issue is the same for ROS v6 if the bridge port member is not a bonded interface everything is working as it should, can anyone confirm if this is not a supported configuration or a bug maybe? thanks
https://help.mikrotik.com/servicedesk/servicedesk/customer/portal/1/SUP-91573 I log a support ticket just in case, thanks in advance !
After experimenting with this I set the MTU to 1492 less than with 1500 on the MTU of the bridge and i was able to create the interface
