Management of remote MT devices across VPN
I am trying to create a tunnel between me and my customer MT LTE devices so that I can manage them remotely when not on my own wireless network. I have the VPN running fine where it runs ALL bandwidth across it (instead of using the providers gateway for Internet traffic), but all I really need is a tunnel from my MT VPN server to all devices and then I can tunnel in and be on the same private VPN network. Have not found a reasonable example online so hoping for some recommendations here.
Shane
That is really simple…
First, you should create a site-to-site VPN Tunnel Between your VPN Server and your VPN Client Main router…
It can be an SSTP Tunnel, an L2TP/IPsec Tunnel, an IPsec tunnel etc…
Here you can see an SSTP Tunnel example https://wiki.mikrotik.com/wiki/Manual:Interface/SSTP#Site-to-Site_SSTP Notice you can do it without any ceretificates, so you can skip all the part that talks about the certificates…
One the Tunnel completes you will be able to reach your Clients Lan Devices…
However, there are security issues here, you must configure you firewall accordingly…
