I’ve just installed SXT LTE in passthrough mode and looks like it works just fine. With this configuration I loose the ability to connect to SXT with winbox or web interface. The device itself will be mounted of the roof and will not be accessible all the time.
Is there any way to keep the ability of remote management in passthrough mode?
if passthrough goint to next RouterBoard then you can check MNDP and discover and connect via dis way to sxt.
If you reach ~80-95Mb then you can consider use bonding from SXTR to RB via 2 cable to increase speed.
One of the best ways is use VLAN as MGMT. Many times at forum, just search.
