I have 3 Mikrotik hAPACs, scattered about the house as access points.
If I move from one end of the house to the other end, since my phone can still see the original access point, it doesn’t change, even though the nearby access point has better signal.
Is there a way to get the Mikrotiks set up to assist in the phone changing from one AP to the other? Reading through CapsMan that doesn’t sound like what it’s for, nor mesh.
All the access points are hard wired, and on the same vlan.
Good luck with unintended consequences, I tried playing with those settings and the person would come back in range and the switch back would not occur…
Its very tricky.
