Why would one mangle pre-routing vs post-routing for QOS?
I’ve seen it both ways but don’t know why.
I’m sure someone will post you a link of the packet flow diagram but it depends on that according to how you are routing the packets. Generally go for pre-routing although for a lot my applications I actually find the forward chain just as useful.
yea, I would see how that would be useful.
My question is how does one make that decision from pre/post routing decision, say on a CCR1036.
It is not very important. However note:
So what I normally do is:
In some cases I also use connection marking to tag connections as low-priority and then set the
DSCP accordingly for packets belonging to the connection. This can also be done post-routing,
befor the above “set priority”. Alternatively, priority can be modified after the “set priority” based
on the connection marks or on packet marks when you do not want to touch DSCP.
- there can only be a single packet mark on a packet, so when you want to use packet-marks
both for routing decisions and for QoS, you need to apply the mark for QoS in post-routing
For routing decisions (and routing marks), wouldn’t you do that pre-routing?
Yes, and therefore do the QoS post-routing to avoid overwriting the mark.
