Mangle: Diffrent Chain, Same Mark
Good day everyone,
What are the differences between these mangle:
Chain Prerouting → Mark Connection
and
Chain Forward → Mark Connection
Concerning to:
  • the packets itself
  • when the packets got marked
  • different uses
Or any answers will be helpful.
So far I am not able to see the differences between the two because both use ‘Mark Connection’.
http://www.mikrotik.com/testdocs/ros/2.9/ip/flow.php
for example, in Prerouting, you will mark packets, which will be processed in Input, not Forward chain
Thanks,
Well… I have seen and done by myself, people use chain prerouting → mark connection AND chain forward → mark connection, to set queue tree, both mangle succeeded.
I can not see logical differences between both mangle, yet.
I hope anybody can help me with this understanding.
Anyone?
If you use simple queues then you need to use prerouting chain (see packet flow).
If using queue tree then forward chain is OK
