I have x86 router machine with 6 ethernet port.
ether1 will using for incloming transaction. and pptp server interface
and another 5 ether port will using for outgoing trafic(Uplink form ISP)
All 6 of IP Address form same ISP (Public &Dynamic IP)
I want to load balancing 5Uplink on 5 ethernet port for PPTP clients Group.
This is what i pre-configuration.
/ interface ethernet
set ether1 name=“income”
set ether2 name=“out1”
set ether3 name=“out2”
set ether4 name=“out3”
set ether5 name=“out4”
set ether6 name=“out5”
/ ip dhcp-client add interface=income user-peer=yes add-default-route=yes disable=no
/ ip dhcp-client add interface=out1 user-peer=yes add-default-route=yes disable=no
/ ip dhcp-client add interface=out2 user-peer=yes add-default-route=yes disable=no
/ ip dhcp-client add interface=out3 user-peer=yes add-default-route=yes disable=no
/ ip dhcp-client add interface=out4 user-peer=yes add-default-route=yes disable=no
/ ip dhcp-client add interface=out5 user-peer=yes add-default-route=yes disable=no
/ interface bridge
add name=“lan” arp=proxy-arp
/ interface bridge port
add interface=income bridge=lan
/ ip address
add address=10.0.0.1/20 interface=lan
/ ip dns
allow-remote-requests=yes
/ ip firewall service-port
set pptp disabled=no
/ ip pool
add name=“pptp” ranges=10.0.0.2-10.0.16.254
/ ppp profile
add name=“pptp-in” local-address=10.0.0.1 remote-address=pptp use-encryption=default only-one=default change-tcp-mss=yes dns-server=10.0.0.1
/ interface pptp-server server
set enabled=yes max-mtu=1460 max-mru=1460 authentication=chap,mschap1,mschap2 default-profile=pptp-in
/ ip firewall nat add chain=srcnat src-address=10.0.0.2-10.0.16.254 action=masquerade
/ ip firewall mangle add chain=prerouting in-interface=lan connection-state=new nth=5,1 action=mark-connection new-connection-mark=conn1 passthrough=yes comment=“” disabled=no
/ ip firewall mangle add chain=prerouting in-interface=lan connection-mark=conn1 action=mark-routing new-routing-mark=conn1 passthrough=no comment=“” disabled=no
/ ip firewall mangle add chain=prerouting in-interface=lan connection-state=new nth=4,1 action=mark-connection new-connection-mark=conn2 passthrough=yes comment=“” disabled=no
/ ip firewall mangle add chain=prerouting in-interface=lan connection-mark=conn2 action=mark-routing new-routing-mark=conn2 passthrough=no comment=“” disabled=no
/ ip firewall mangle add chain=prerouting in-interface=lan connection-state=new nth=3,1 action=mark-connection new-connection-mark=conn3 passthrough=yes comment=“” disabled=no
/ ip firewall mangle add chain=prerouting in-interface=lan connection-mark=conn3 action=mark-routing new-routing-mark=conn3 passthrough=no comment=“” disabled=no
/ ip firewall mangle add chain=prerouting in-interface=lan connection-state=new nth=2,1 action=mark-connection new-connection-mark=conn4 passthrough=yes comment=“” disabled=no
/ ip firewall mangle add chain=prerouting in-interface=lan connection-mark=conn4 action=mark-routing new-routing-mark=conn4 passthrough=no comment=“” disabled=no
/ ip firewall mangle add chain=prerouting in-interface=lan connection-state=new action=mark-connection new-connection-mark=conn5 passthrough=yes comment=“” disabled=no
/ ip firewall mangle add chain=prerouting in-interface=lan connection-mark=conn5 action=mark-routing new-routing-mark=conn5 passthrough=no comment=“” disabled=no
/ ip firewall nat add chain=srcnat connection-mark=conn1 action=masquerade out-interface=out1 comment=“” disabled=no
/ ip firewall nat add chain=srcnat connection-mark=conn2 action=masquerade out-interface=out2 comment=“” disabled=no
/ ip firewall nat add chain=srcnat connection-mark=conn3 action=masquerade out-interface=out3 comment=“” disabled=no
/ ip firewall nat add chain=srcnat connection-mark=conn4 action=masquerade out-interface=out4 comment=“” disabled=no
/ ip firewall nat add chain=srcnat connection-mark=conn5 action=masquerade out-interface=out5 comment=“” disabled=no
/ ip route add dst-address=0.0.0.0/0 gateway=out1 scope=255 target-scope=10 routing-mark=conn1 comment=“” disabled=no
/ ip route add dst-address=0.0.0.0/0 gateway=out2 scope=255 target-scope=10 routing-mark=conn2 comment=“” disabled=no
/ ip route add dst-address=0.0.0.0/0 gateway=out3 scope=255 target-scope=10 routing-mark=conn3 comment=“” disabled=no
/ ip route add dst-address=0.0.0.0/0 gateway=out4 scope=255 target-scope=10 routing-mark=conn4 comment=“” disabled=no
/ ip route add dst-address=0.0.0.0/0 gateway=out5 scope=255 target-scope=10 routing-mark=conn5 comment=“” disabled=no
/ ip route add dst-address=0.0.0.0/0 gateway=out1 scope=255 target-scope=10 comment=“” disabled=no
Question..
Actually I don’t much know about mangle. so i got few configuration example form googling.
This confiuration looks like do loadbalancing based on connection. but I want to make loadbalancing based on PPTP-connection.
I mean, If PPTP client login to “lan” interface they will get local ip address from “ip pool” then loadbalancer asign 1 of 5 “upstram” port for this coneection until disconnect or logout.
what i need to change?
Jin Lee
