I am trying to setup mangle for marking voip packets using a hEX lite. I have gone through and setup 4 rules, 2 to mark connections and 2 to mark packets. The pics im attaching where ive put the boxes all have matching IPs and ports in those boxes I just don’t want to give the IP out.
You are marking the connection (first rule) with its own connection mark, remove “connection mark” from the first rule and on the second rule, disable passthrough.
