We have replaced an old Mikrotik router 6.11 version with new shipped with version 6.30.2.
We would like to use the same queue settings so mangle and queue tree has been copied with export command.
/ip firewall mangle
add action=mark-connection chain=prerouting comment=UPLOAD new-connection-mark=UPLOAD src-address=192.168.1.0/24
add action=mark-packet chain=prerouting connection-mark=UPLOAD new-packet-mark=UPLOAD
add action=mark-connection chain=postrouting comment=VOIP_download dst-address-list=GSMGateways new-connection-mark=VOIP_download
add action=mark-packet chain=postrouting connection-mark=VOIP_download new-packet-mark=VOIP_download
add action=mark-connection chain=prerouting comment=VOIP_upload new-connection-mark=VOIP_upload src-address-list=GSMGateways
add action=mark-packet chain=prerouting connection-mark=VOIP_upload new-packet-mark=VOIP_upload
add action=mark-connection chain=postrouting comment=DOWNLOAD connection-state=new dst-address=192.168.1.0/24 new-connection-mark=DOWNLOAD
add action=mark-packet chain=postrouting connection-mark=DOWNLOAD new-packet-mark=DOWNLOAD
add action=mark-connection chain=prerouting comment=SERVICES_upload dst-port=53 new-connection-mark=SERVICES_upload protocol=udp src-address=\
192.168.1.0/24
add action=mark-connection chain=prerouting dst-port=993,25,26,2525,587,465,110,995,143 new-connection-mark=SERVICES_upload protocol=tcp src-address=\
192.168.1.0/24
add action=mark-packet chain=prerouting connection-mark=SERVICES_upload new-packet-mark=SERVICES_upload
add action=mark-connection chain=postrouting comment=SERVICES_download dst-address=192.168.1.0/24 new-connection-mark=SERVICES_download protocol=udp \
src-port=53
add action=mark-connection chain=postrouting dst-address=192.168.1.0/24 new-connection-mark=SERVICES_download protocol=tcp src-port=\
add action=mark-packet chain=postrouting connection-mark=SERVICES_download new-packet-mark=SERVICES_download
add action=mark-connection chain=prerouting comment=HTTP_upload dst-port=80,443 new-connection-mark=HTTP_upload protocol=tcp src-address=192.168.1.0/24
add action=mark-packet chain=prerouting connection-mark=HTTP_upload new-packet-mark=HTTP_upload
add action=mark-connection chain=postrouting comment=HTTP_download dst-address=192.168.1.0/24 new-connection-mark=HTTP_download protocol=tcp src-port=\
80,443
add action=mark-packet chain=postrouting connection-mark=HTTP_download new-packet-mark=HTTP_download
/queue tree
add name=DOWNLOAD packet-mark=DOWNLOAD parent=global queue=default
add name=UPLOAD packet-mark=UPLOAD parent=global queue=default
add limit-at=6M max-limit=11M name=VOIP_download packet-mark=VOIP_download parent=DOWNLOAD priority=1 queue=default
add max-limit=11M name=OTHER_download packet-mark=DOWNLOAD parent=DOWNLOAD queue=default
add limit-at=6M max-limit=11M name=VOIP_upload packet-mark=VOIP_upload parent=UPLOAD priority=1 queue=default
add max-limit=11M name=OTHER_upload packet-mark=UPLOAD parent=UPLOAD queue=default
add max-limit=11M name=SERVICES_download packet-mark=SERVICES_download parent=DOWNLOAD priority=3 queue=default
add max-limit=11M name=HTTP_download packet-mark=HTTP_download parent=DOWNLOAD priority=6 queue=default
add max-limit=11M name=SERVICES_upload packet-mark=SERVICES_upload parent=UPLOAD priority=3 queue=default
add max-limit=11M name=HTTP_upload packet-mark=HTTP_upload parent=UPLOAD priority=6 queue=default
As you can see in connections tab, there is a connection mark HTTP_download but in magle tab there are no bytes (not only for HTTP_download but all mangles) so the queue tree does not work.
Configuration is standard ethernet - routing mode with WAN and local switch connected to port ether2-master-local.
Can someone explain what I am doing wrong? thank you
