I’m using RB150 (routeros 3.0rc6) device to route traffic between several LAN’s and adsl modem (btw many thanks to developers for implementing “switch” functionality .
Everything works pretty good, however I’ve got problem trying to mark specific (for example some kind of UDP) VPN (usual PPTP, visible as GRE in sniffer) packets with mangle facility.
That rule successfully catches all pptp packets flowing thru the router, however at this time I’ve found no posibility to filter only UDP (for example) packets from them, for example combined rule again misses all the (here comes a list of protocols/headers in a packet) Ethernet/IP/GRE/UDP packets:
that is the answer. VPN is secure connection, it encapsulates all user’s traffic and hides it from any kind of sniffing. so the router see only GRE connection, and cannot get a look inside
Actually secure/non-secure is controlled by VPN tunnel settings, and our provider (Atlant-telecom, you should know him prohibits encryption). I’ve added the sample packet dump below. I don’t want a general solution, just thought there should be resolution in my case, when the actual packet is going after GRE header.
Offtopic: have you found any mikrotik dealers in belarus?
Packet #1, Direction: Out, Time:13:47:42.647979, Size: 102
Ethernet II
Destination MAC: 00:0C:42:12:14:05
Source MAC: 00:11:2F:42:D5:29
Ethertype: 0x0800 (2048) - IP
IP
IP version: 0x04 (4)
Header length: 0x05 (5) - 20 bytes
Type of service: 0x00 (0)
Precedence: 000 - Routine
Delay: 0 - Normal delay
Throughput: 0 - Normal throughput
Reliability: 0 - Normal reliability
Total length: 0x0058 (88)
Flags
Don’t fragment bit: 0 - May fragment
More fragments bit: 0 - Last fragment
Fragment offset: 0x0000 (0)
Time to live: 0x80 (128)
Protocol: 0x2F (47) - GRE
Checksum: 0x06C3 (1731) - correct
Source IP: 192.168.2.24
Destination IP: 10.1.50.1
IP Options: None
GRE
Payload present: 0x01 (1)
Protocol: 0x880B (34827)
Payload length: 0x0038 (56)
Call ID: 0xB1C7 (45511)
Sequence number: 0x00000025 (37)
Protocol: 0x0021 (33) - IPv4
IP
Total length: 0x0034 (52)
Flags
Protocol: 0x11 (17) - UDP
Checksum: 0x6E5B (28251) - correct
Source IP: 10.128.6.203
Destination IP: 194.158.195.131
IP Options: None
UDP
Source port: 1114
Destination port: 53
Length: 0x0020 (32)
Checksum: 0xE0B2 (57522) - correct
DNS
Response packet: 0
Operation code: 0x00 (0) - Standard query
Flags
Authoritative Answer: 0
Truncation: 0
Recursion Desired: 1
Recursion Available: 0
Question records: 0x0001 (1)
Answer records: 0x0000 (0)
Authority records: 0x0000 (0)
Additional records: 0x0000 (0)
Question section
Record: 0x1 (1)
Type: 0x0006 (6) - SOA
Class: 0x0001 (1) - IN
It seems it just captures all the packets containing gre header, because when I activate the rule with connectiontype=gre it immideatly matches packets flow from old PPTP sessions.
Buying license is easy, but I couldn’t say that about hardware… I’ve bought 2 RB150 during my trip to poland, but I don’t know were to get some more now (the nearest places are Moscow and Kiev)…
Hm, don’t know what the “GRE NAT helper” mean, haven’t seen in options/docs anything like that There are no NAT / other Mangle rules defined (if you mean something like that).
Apply some marks for the beginning Basically it was the proof of concept, however I thought about getting statistics for different kind of traffic and (maybe) setting priorities.
Yes, pptp service port is turned on (i’ve got no gre here, and also got no connection-type=gre, just pptp, but it works like described before). However that doesn’t matter that much. This way or that way I could match GRE traffic, but I couldn’t match/analyse encapsulated packet itself, even if it is unecrypted/uncompressed. That is the point of interest
