Good day, i have found a problem, external IP address doesnt ping, from PC, which traffic pass through mangle rules.
Mangle:
/ip firewall mangle
add action=mark-routing chain=prerouting comment=Asterisk dst-address-list=!WorkSpace new-routing-mark=ABV-routing passthrough=no src-address=192.168.0.247
add action=mark-routing chain=prerouting comment="Evgeniy Panov" dst-address-list=!WorkSpace new-routing-mark=ABV-routing passthrough=no src-address=192.168.0.24
add action=mark-routing chain=prerouting comment=Docker dst-address-list=!WorkSpace new-routing-mark=ABV-routing passthrough=no src-address=192.168.0.239
add action=mark-routing chain=prerouting comment="WiFi users" dst-address-list=!WorkSpace new-routing-mark=ABV-routing passthrough=no src-address=10.1.0.0/16
add action=mark-routing chain=prerouting comment="Sergey Morev" dst-address-list=!WorkSpace new-routing-mark=DOMRU-routing passthrough=no src-address=192.168.0.111
add action=mark-routing chain=prerouting comment=Users dst-address-list=!WorkSpace new-routing-mark=DOMRU-routing passthrough=no src-address=192.168.0.20-192.168.0.110
add action=mark-connection chain=input in-interface=WAN-if1 new-connection-mark=ABV-con passthrough=no
add action=mark-connection chain=input in-interface=WAN-if2 new-connection-mark=DOMRU-con passthrough=no
add action=mark-routing chain=prerouting dst-address-list=!WorkSpace new-routing-mark=ATC passthrough=no src-address=192.168.0.191
add action=mark-routing chain=prerouting dst-address-list=!WorkSpace new-routing-mark=ATC passthrough=no src-address=192.168.0.192
add action=mark-routing chain=prerouting dst-address-list=!WorkSpace new-routing-mark=ABV-routing passthrough=yes src-address=192.168.0.24
add action=mark-routing chain=output connection-mark=ABV-con new-routing-mark=ABV-routing passthrough=no
add action=mark-routing chain=output connection-mark=DOMRU-con new-routing-mark=DOMRU-routing passthrough=no
If, we are try to ping 89.185.94.241 from 192.168.0.247 it return:
--- 89.185.94.241 ping statistics ---
3 packets transmitted, 0 received, 100% packet loss, time 1999ms
If, we are try to traceroute 89.185.94.241 from 192.168.0.247 it return:
traceroute to 89.185.94.241 (89.185.94.241), 30 hops max, 60 byte packets
1 * * *
2 * * *
3 * * *
4 * * *
5 * * *
6 *^C
Tracert from 89.185.94.241 to 192.168.0.247 goes to Internet:
tool traceroute src-address=89.185.94.241 address=192.168.0.247
# ADDRESS LOSS SENT LAST AVG BEST WORST STD-DEV STATUS
1 89.185.94.254 0% 1 0.7ms 0.7 0.7 0.7 0
2 89.185.92.33 0% 1 1.1ms 1.1 1.1 1.1 0
3 10.221.221.1 0% 1 0.7ms 0.7 0.7 0.7 0
4 37.60.16.186 0% 1 0.6ms 0.6 0.6 0.6 0
5 195.218.253.241 0% 1 1.7ms 1.7 1.7 1.7 0
6 79.104.245.102 0% 1 29.6ms 29.6 29.6 29.6 0
7 79.104.250.66 0% 1 36ms 36 36 36 0 <MPLS:L=407874,E=0>
8 79.104.226.254 0% 1 32.8ms 32.8 32.8 32.8 0
9 100% 1 timeout
10 0% 1 0ms
Route in network 192.168.0.0 has status DAC.
If we disable ip route rule
ip route rule print
Flags: X - disabled, I - inactive
0 src-address=89.185.94.241/32 dst-address=0.0.0.0/0 action=lookup table=ABV-routing
1 src-address=89.185.94.175/32 dst-address=0.0.0.0/0 action=lookup table=ABV-routing
2 src-address=109.194.175.23/32 dst-address=0.0.0.0/0 action=lookup table=DOMRU-routing
We are watch next result:
tool traceroute 192.168.0.247 src-address=89.185.94.241
1 192.168.0.247 0% 5 0.2ms 0.3 0.2 0.6 0.1
We can see that from router 192.168.0.247 trace are reachable, and vice versa:
1 89.185.94.241 (89.185.94.241) 0.195 ms 0.258 ms 0.166 ms
But ping dont
4 packets transmitted, 0 received, 100% packet loss, time 2998ms
Howewer, if we disable mangle rule:
The ping will successful:
ping 89.185.94.241
PING 89.185.94.241 (89.185.94.241) 56(84) bytes of data.
64 bytes from 89.185.94.241: icmp_seq=1 ttl=64 time=0.318 ms
64 bytes from 89.185.94.241: icmp_seq=2 ttl=64 time=0.169 ms
64 bytes from 89.185.94.241: icmp_seq=3 ttl=64 time=0.200 ms
I supposed that, problem in mangle rules, but where ?
Echo tests are successful ONLY when Ip route rule and Mangle rule are disable
