I am using Mangle and Queue trees for shaping my customers.
As traffic is increasing I have got a feeling that throughput is somehow restricted at some point.
I can see that the %CPU is rising, and the vast of it is consumed by the firewall.
Therefore I am thinking of optimizing my mangle rules and I need some advice from you experts.
I have just moved conn marking to separate chains, and the structure of mangle is now as follows:
(For simplicity only 2 bandwidth classes are included, a lot more exist, presumably calling even more for optimizing)
/ip firewall mangle
# Skip marking of GRE and SNMP, then jump to classify chain for new conns
add action=return chain=prerouting comment="Do not classify GRE (EOIP)" \
log-prefix=GRE protocol=gre
add action=return chain=prerouting comment="Do not classify SNMP" dst-port=161 \
log-prefix=SNMP protocol=udp
add action=jump chain=prerouting comment="Classify non-marked conns" \
connection-mark=no-mark connection-state=new jump-target=classify_up
# Mark upload packets based on connmarks
add action=mark-packet chain=prerouting comment=\
"Mark Packet upload Private 3000:" connection-mark=conn_Private_3000_up \
new-packet-mark=packet_Private_3000_up passthrough=no
"Mark Packet upload Private 5000:" connection-mark=conn_Private_5000_up \
new-packet-mark=packet_Private_5000_up passthrough=no
add action=return chain=postrouting comment="Do not classify GRE (EOIP)" \
add action=return chain=postrouting comment="Do not classify SNMP" log-prefix=\
SNMP protocol=udp src-port=161
add action=jump chain=postrouting comment="Classify non-marked conns" \
connection-mark=no-mark connection-state=new jump-target=classify_down
add action=mark-packet chain=postrouting comment=\
"Mark Packet download Private 6000:" connection-mark=conn_Private_6000_down \
new-packet-mark=packet_Private_6000_down passthrough=no
"Mark Packet download Private 10000:" connection-mark=\
conn_Private_10000_down new-packet-mark=packet_Private_10000_down \
passthrough=no
# Chain for classifying download traffic
add action=mark-connection chain=classify_down comment=\
"Mark Conn upload Private 10000/5000:" connection-state="" \
new-connection-mark=conn_Private_5000_up passthrough=yes src-address-list=\
Adr_Private_10000/5000
"Mark Conn upload Private 6000/3000:" connection-state="" \
new-connection-mark=conn_Private_3000_up passthrough=yes src-address-list=\
Adr_Private_6000/3000
add action=return chain=classify_down
# Chain for classifying upload traffic
add action=mark-connection chain=classify_up comment=\
"Mark Conn download Private 6000/3000:" connection-state="" \
dst-address-list=Adr_Private_6000/3000 new-connection-mark=\
conn_Private_6000_down passthrough=yes
"Mark Conn download Private 10000/5000:" connection-state="" \
dst-address-list=Adr_Private_10000/5000 new-connection-mark=\
conn_Private_10000_down passthrough=yes
add action=return chain=classify_up
I have the following questions:
Is testing for connection-mark=no-mark neccessary in addition to connection-state=new? I assume a new connection won’t have any marks?
As the “classifying” chains are only hit by new connections, I guess they won’t add much load. But can I use passthrough=no in the classifying chains? Will execution then return to the rule succeeding the jump rule, thus moving straight on to packet marking for new connections as well?
I am thinking of re-ordering the packet mark rules. Let’s say 80% of my customers are on the 6000/3000 plan, then the vast of the packets will match only the rules for 6000/3000, right?
Will it then be a good idea to move these rules above the 10000/5000 rules, avoiding a false test for most of the traffic against the 10000/5000 address list before moving to the right rule?
Any other suggestions?
( I know there are other ways to avoid running GRE/SNMP and other “administrative” traffic through the classifier but that’s not my concern here)
