Hi All,
Long time reader, first time poster.
My network is running fine. I successfully implemented Layer7 protocol to block tiktok access in my home network. Wanted to explore using Mangle rules to identify tiktok ip addresses and block access using firewall rules with address list. Now, the address list generated by the Mangle rules lists my DNS address and even the router itself, bringing the entire network down.
In the YT tutorials, no one seems to have their DNS servers picked up by the mangle rules. I’m wondering if mine was picked up because I forced traffic to my defined DNS servers (so that my kid doesn’t bypass blocked sites).
How do I get myself out of this? Please help. Thank you.
# 2024-10-23 23:30:56 by RouterOS 7.16.1
# software id = **ELIDED**
# model = RB5009UG+S+
# serial number = **ELIDED**
add comment="Guest Bridge" name="Bridge GuestVLAN" port-cost-mode=short
add comment=defconf name=MasterBridge port-cost-mode=short
set [ find default-name=ether1 ] comment="2.5G WAN Port" name="ether1 WAN"
/interface vlan
add comment="VLAN Setup for Guest Network" interface=MasterBridge name=\
GuestVLAN vlan-id=99
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=10.0.0.11-10.0.0.248
add name=GuestPool ranges=192.168.0.2-192.168.0.250
add address-pool=dhcp interface=MasterBridge lease-time=1d name=HomeDHCP
add address-pool=GuestPool interface="Bridge GuestVLAN" lease-time=2h name=\
"Guest DHCP"
/ip smb users
add bridge=MasterBridge comment=defconf interface=ether2 internal-path-cost=\
10 path-cost=10
add bridge=MasterBridge comment=defconf interface=ether3 internal-path-cost=\
10 path-cost=10
add bridge=MasterBridge comment=defconf interface=ether4 internal-path-cost=\
10 path-cost=10
add bridge=MasterBridge comment=defconf interface=ether5 internal-path-cost=\
10 path-cost=10
add bridge=MasterBridge comment=defconf interface=ether6 internal-path-cost=\
10 path-cost=10
add bridge=MasterBridge comment=defconf interface=ether7 internal-path-cost=\
10 path-cost=10
add bridge=MasterBridge comment=defconf interface=ether8 internal-path-cost=\
10 path-cost=10
add bridge=MasterBridge comment=defconf interface=sfp-sfpplus1 \
internal-path-cost=10 path-cost=10
add bridge="Bridge GuestVLAN" comment="Join Guest VLAN to Guest Bridge" \
ingress-filtering=no interface=GuestVLAN internal-path-cost=10 path-cost=\
10 trusted=yes
set udp-timeout=10s
set discover-interface-list=none lldp-med-net-policy-vlan=1
/ipv6 settings
set disable-ipv6=yes
/interface bridge vlan
add bridge=MasterBridge comment="Home Network UNTAGGED" untagged="MasterBridge\
,ether2,ether3,ether4,ether5,ether6,ether7,ether8,sfp-sfpplus1" vlan-ids=\
add bridge="Bridge GuestVLAN" comment="Guest LAN Tagging" tagged=GuestVLAN \
vlan-ids=99
add comment=defconf interface=MasterBridge list=LAN
add comment=defconf interface="ether1 WAN" list=WAN
add comment="Guest Bridge definition for LAN" interface="Bridge GuestVLAN" \
list=LAN
add address=10.0.0.1/24 comment=defconf interface=MasterBridge network=\
10.0.0.0
add address=192.168.0.1/24 comment="IP Range for Guest Network" interface=\
"Bridge GuestVLAN" network=192.168.0.0
/ip dhcp-client
add comment=defconf interface="ether1 WAN" use-peer-dns=no
add address=10.0.0.0/24 comment="Home network" dns-server=10.0.0.1 gateway=\
10.0.0.1 netmask=24
add address=192.168.0.0/24 comment="Guest network definitions" dns-server=\
10.0.0.1 gateway=192.168.0.1
set allow-remote-requests=yes cache-size=104857KiB servers=\
94.140.14.15,94.140.15.16 use-doh-server=\
https://family.adguard-dns.com/dns-query verify-doh-cert=yes
/ip dns static
add address=10.0.0.1 comment=defconf name=router.lan type=A
/ip firewall address-list
add address=10.0.0.2-10.0.0.254 list="Home IP"
add address=192.168.0.2-192.168.0.250 list="Guest IP"
add address=23.47.190.216 list=Blocked_IP
add address=184.87.193.92 list=Blocked_IP
add address=184.87.193.97 list=Blocked_IP
add address=23.47.190.208 list=Blocked_IP
add address=23.52.171.208 list=Blocked_IP
add address=184.87.193.72 list=Blocked_IP
add address=23.54.155.171 list=Blocked_IP
add address=23.52.171.226 list=Blocked_IP
add address=2.19.198.248 list=Blocked_IP
add address=94.140.15.15 list=Blocked_IP
add address=94.140.14.14 list=Blocked_IP
add address=94.140.14.15 list=Blocked_IP
add address=10.0.0.1 list=Blocked_IP
add address=96.17.180.45 list=Blocked_IP
add address=23.47.190.162 list=Blocked_IP
add address=23.45.207.199 list=Blocked_IP
established,related,untracked
invalid
add action=drop chain=input comment="RT: Drop TCP (DNS) from outside WAN" \
dst-port=53 in-interface="ether1 WAN" protocol=tcp src-address=0.0.0.0/0
add action=drop chain=input comment="RT: Drop UDP (DNS) from outside WAN" \
dst-port=53 in-interface="ether1 WAN" protocol=udp src-address=0.0.0.0/0
in-interface-list=!LAN
add action=reject chain=input comment="RT: Stop traffic to Blocked_IP" \
disabled=yes dst-address-list=Blocked_IP reject-with=\
icmp-network-unreachable
add action=reject chain=forward comment=\
"RT: Blocked users from Internet [based on Firewall:Address list]" \
reject-with=icmp-network-unreachable src-address-list="Blocked users"
connection-state=invalid
"RT: allow Guest LAN to 10.0.0.249 [printer]" dst-address=10.0.0.249 \
in-interface-list=LAN
add action=accept chain=forward comment="RT: Accept Guest to WAN Interface" \
out-interface-list=WAN src-address-list="Guest IP"
add action=accept chain=forward comment="RT: Accept HomeLAN to WAN interface" \
out-interface-list=WAN src-address-list="Home IP"
add action=accept chain=forward comment="RT: Port forwarding" \
connection-nat-state=dstnat
"RT: Unconditional drop/reject rule at the end of forward chain" \
/ip firewall mangle
add action=add-dst-to-address-list address-list=Blocked_IP \
address-list-timeout=none-static chain=prerouting comment=tiktok content=\
tiktok src-address=10.0.0.0/24
address-list-timeout=none-static chain=prerouting comment=tiktokv \
content=tiktokv src-address=10.0.0.0/24
address-list-timeout=none-static chain=prerouting comment=tiktokcdn \
content=tiktokcdn src-address=10.0.0.0/24
address-list-timeout=none-static chain=prerouting comment=byteoversea \
content=.byteoversea.com src-address=10.0.0.0/24
address-list-timeout=none-static chain=prerouting comment=ibyteimg \
content=.ibyteimg.com src-address=10.0.0.0/24
address-list-timeout=none-static chain=prerouting comment=ibytedtos \
content=.ibytedtos.com src-address=10.0.0.0/24
address-list-timeout=none-static chain=prerouting comment=myqcloud \
content=.myqcloud.com src-address=10.0.0.0/24
address-list-timeout=none-static chain=prerouting comment=ttwstatic \
content=ttwstatic src-address=10.0.0.0/24
address-list-timeout=none-static chain=prerouting comment=musical.ly \
content=.musical.ly src-address=10.0.0.0/24
address-list-timeout=none-static chain=prerouting comment=zhiliaoapp \
content=zhiliaoapp src-address=10.0.0.0/24
address-list-timeout=none-static chain=prerouting comment=bytecdn \
content=bytecdn src-address=10.0.0.0/24
address-list-timeout=none-static chain=prerouting comment=byted.org \
content=.byted.org src-address=10.0.0.0/24
address-list-timeout=none-static chain=prerouting comment=footprint \
content=.footprint.net src-address=10.0.0.0/24
address-list-timeout=none-static chain=prerouting comment=wsdvs content=\
.wsdvs.com src-address=10.0.0.0/24
address-list-timeout=none-static chain=prerouting comment=worldfcdn \
content=worldfcdn src-address=10.0.0.0/24
address-list-timeout=none-static chain=prerouting comment=musemuse \
content=.musemuse.cn src-address=10.0.0.0/24
add action=accept chain=dstnat comment=\
"Allow Player2 PC to use alternative DNS" dst-port=53 protocol=tcp \
src-address=10.0.0.5
"Allow Player2 PC to use alternative DNS" dst-port=53 protocol=udp \
add action=dst-nat chain=dstnat comment=\
"Transparent DNS - TCP side traffic to port 53" dst-port=53 protocol=tcp \
to-addresses=94.140.15.16 to-ports=53
"Transparent DNS - UDP side traffic to port 53" dst-port=53 protocol=udp \
to-addresses=94.140.14.15 to-ports=53
/ip firewall raw
add action=drop chain=prerouting comment="Reject Blocked IP" disabled=yes \
/ip ipsec profile
add blackhole comment=\
"Router does not answer LAN address from external [rule 1]" disabled=no \
distance=1 dst-address=10.0.0.0/8 gateway="" routing-table=main \
suppress-hw-offload=no
"Router does not answer internal LAN address from external [rule 2]" \
disabled=no distance=1 dst-address=192.168.0.0/16 gateway="" \
routing-table=main suppress-hw-offload=no
