plisken
November 19, 2020, 11:18am
1
I want to limit the total download and upload speed and want to start marking the traffic.
Is this the correct method that I am showing here?
If not can you help me please
/ip firewall mangle
add action=mark-packet chain=prerouting comment=upload-all-bandwidth in-interface-list=WAN new-packet-mark=upload-all-bandwidth passthrough=yes src-address=0.0.0.0/0
add action=mark-packet chain=postrouting comment=download-all-bandwitdth dst-address=0.0.0.0/0 new-packet-mark=download-all-bandwidth out-interface-list=WAN passthrough=yes
CZFan
November 19, 2020, 9:52pm
2
Suggest you mark connections first, then packets of these connections
plisken
November 20, 2020, 7:34am
3
Thanks, i do that and try it out.
plisken
November 20, 2020, 8:48am
4
Is this correct?
/ip firewall mangle
add action=mark-connection chain=prerouting comment=upload-conn-all-bandwidth in-interface-list=WAN new-connection-mark=upload-full-bandwidth-conn passthrough=yes src-address=0.0.0.0/0
add action=mark-connection chain=postrouting comment=download-conn-all-bandwitdth dst-address=0.0.0.0/0 new-connection-mark=download-full-bandwidth-conn out-interface-list=WAN passthrough=yes
add action=mark-packet chain=prerouting comment=upload-all-bandwidth connection-mark=upload-full-bandwidth-conn in-interface-list=WAN new-packet-mark=upload-all-bandwidth passthrough=yes src-address=0.0.0.0/0
add action=mark-packet chain=postrouting comment=download-all-bandwitdth connection-mark=download-full-bandwidth-conn dst-address=0.0.0.0/0 new-packet-mark=download-all-bandwidth out-interface-list=WAN passthrough=yes
WeWiNet
November 20, 2020, 9:02am
5
What works for me is:
/ip firewall mangle
add action=mark-connection chain=forward comment="DSL: DL: All traffic" in-interface=WAN1-DSL new-connection-mark=\
All_DL_connection passthrough=yes
add action=mark-connection chain=forward comment="DSL: UL: All traffic" new-connection-mark=All_UL_connection out-interface=\
WAN1-DSL passthrough=yes
Then from there I use the IP address to differentiate the sub queues… here I only show one IP range…
add action=mark-packet chain=forward comment=" DSL: DL: HOME_pkt_mark" connection-mark=All_DL_connection dst-address=\
192.168.99.10-192.168.99.200 new-packet-mark=Home_DL_pkt_mark passthrough=no
add action=mark-packet chain=forward comment=" DSL: UL: HOME_pkt_mark" connection-mark=All_UL_connection \
new-packet-mark=HOME_UL_pkt_mark packet-mark="" passthrough=no routing-mark="" src-address=192.168.99.10-192.168.99.200
Once this done and their traffic counter increase you know thye work.
Then go to Queue tree and set up rules…
/queue tree
add comment="DSL: DL: Main DL queue (all traffic)" limit-at=5M max-limit=5500k name="Main DL" parent=global priority=1 queue=\
ethernet-default
add burst-limit=5500k burst-threshold=5M burst-time=3m20s comment=" DSL: DL: Home DL queue" limit-at=3500k max-limit=5M \
name=Home_DL packet-mark=Home_DL_pkt_mark parent="Main DL" priority=2 queue=default
add comment="DSL: UL: Main UL queue (all traffic)" limit-at=760k max-limit=830k name="Main UL" parent=global priority=1 \
queue=ethernet-default
add burst-limit=800k burst-threshold=600k burst-time=3m20s comment=" DSL: UL: Home UL queue" limit-at=500k max-limit=\
650k name="Home UL" packet-mark=HOME_UL_pkt_mark parent="Main UL" priority=2 queue=default
CZFan
November 20, 2020, 12:34pm
6
I dont have full view of the environment you are doing this, but think it will be safe to say:
Remove src/dst ranges, you have in interface and the current src/dst ranges is for all anyway
I will not use interface list, but rather interface itself, you might have multiple interface in WAN as example
Add “connection-mark=no-mark” to the connection mark rules so when connection is already marked, does not have to redo it
Change the post routing to pre routing
plisken
November 22, 2020, 1:16pm
7
Thanks for your reply
I want to determine the total down and upload to the internet for one subnet.
To then configure PCQ with the created total down and upload rule as parent.
