Mangle
Hello.
How can I use Mangle to mark packets comming/going from/to a vlan?
Thank you for accorded time!
First create an address list with the subnet present on the vlan
/ip firewall address-list
add address=1.2.3.0/24 disabled=no list=SomeVLANsubnet
Then mark in mangle
/ip firewall mangle
add action=mark-connection chain=prerouting comment="Connections from the VLAN" connection-mark=no-mark disabled=no new-connection-mark=Con_from_VLAN passthrough=no src-address-list=SomeVLANsubnet
add action=mark-connection chain=prerouting comment="Connections to the VLAN" connection-mark=no-mark disabled=no dst-address-list=SomeVLANsubnet new-connection-mark=Con_to_VLAN passthrough=no
My VLANs actually split the WAN in metro and external traffic so they are dinamically described by BGP and I don’t have a list of IPs/Subnets.
How can I baypass that?
Regards,
Ioan Capcea
You will have to use the forward chain for incoming connections, and sort it out by interface.
/ip firewall mangle
add action=mark-connection chain=prerouting comment="Connections from the VLAN" connection-mark=no-mark disabled=no new-connection-mark=Con_from_VLAN passthrough=no in-interface=someVlanInterface
add action=mark-connection chain=forward comment="Connections to the VLAN" connection-mark=no-mark disabled=no new-connection-mark=Con_to_VLAN passthrough=no out-interface=someVlanInterface
