I have a setup with multiple routers in two OSPF area’s, which basicly runs fine. Simplified it looks like this :
+---+ rtr-B1 +----+
Net-A -------+ rtr-A +-----+ |
+---+ rtr-B2 +----+
+----+ rtr-C1 +------ Net-C1
+----+ rtr-C2 +------ Net-C2
+----+ rtr-C3 +------ Net-C3
Area 0.0.0.2 Area 0.0.0.3
Router A has two equal routes for netA to NetC1 to 3, Just like NetC1 to 3 have two equal routes to NetA. By nature it will now load-balance over router B1 & B2.
And so the route to Net-A seen from Net-Cx looks like
[admin@net-C1] > ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
5 ADo 192.168.1.0/24 10.217.217.1 110
10.217.217.2
Due to the locations and links available, we prefer to have rtr-b1 take the whole load and rtr-B2 takes over only if B1 fails.
I played with all kinds of settings, tried OSPF in/out filters and even changed all interfaces on trt-B2 to 10mb, but nothing changes the routing tables.
How can I manipulate OSPF to avoid load-balance and route over rtr-B1 and have rtr-B2 take over on failure only?
rtr-b1
/routing ospf instance
set [ find default=yes ] disabled=yes redistribute-connected=as-type-2 redistribute-static=as-type-2 router-id=0.0.0.1
add name=mgmt redistribute-other-ospf=as-type-1 redistribute-static=as-type-1 router-id=10.17.17.101
add name=routenet-2 redistribute-other-ospf=as-type-1 redistribute-static=as-type-1 router-id=10.217.217.1
/routing ospf area
add area-id=0.0.0.3 instance=mgmt name=area-mgmt
add area-id=0.0.0.2 instance=routenet-2 name=routenet-2
add address=10.217.217.1/24 interface=ether2 network=10.217.217.0
add address=10.17.17.1/24 interface=ether1 network=10.17.17.0
add action=accept chain=forward
add action=accept chain=input
/routing ospf network
add area=routenet-2 network=10.217.217.0/24
add area=area-mgmt network=10.17.17.0/24
rtr-b2
set [ find default=yes ] disabled=yes redistribute-connected=as-type-2 redistribute-static=as-type-2 router-id=0.0.0.2
add name=mgmt redistribute-other-ospf=as-type-1 redistribute-static=as-type-1 router-id=10.17.17.2
add name=routenet-2 redistribute-other-ospf=as-type-1 redistribute-static=as-type-1 router-id=10.217.217.2
/routing ospf area
add address=10.217.217.2/24 interface=ether2 network=10.217.217.0
add address=10.17.17.2/24 interface=ether1 network=10.17.17.0
rtr-c
set [ find default=yes ] redistribute-connected=as-type-1 redistribute-static=as-type-1 router-id=0.0.0.10
add name=routenet-2 redistribute-connected=as-type-1 redistribute-other-ospf=as-type-1 redistribute-static=as-type-1 router-id=10.217.217.101
/routing ospf area
add address=10.151.14.1/24 interface=ether3 network=10.151.14.0
add address=10.217.217.10/24 interface=ether2 network=10.217.217.0
add address=10.151.15.1/24 interface=ether4 network=10.151.15.0
/routing ospf interface
add interface=ether2 network-type=broadcast
