mANT22 or mANT24
I just bought 4 pieces of mANT30 and can not wait to test them, even though I would have preferred a model with two n-female connectors instead of just the model with rp-sma.
mANT30 is sure to be an excellent product for long link but would be very useful for us to work with smaller dish diameter 30 cm. or 40 cm. maximum of 22 or 24 dBi gain for use in short link with high throughput. So my request is when we find mANT22 or mANT24 or something else,
cetalfio
Use QRT-5 for 23dBi
QRT-5 could be a solution but the 24 dBi dish antennas usually have 9° beamwith that can be a big advantage in some situations (beamwith 10,5° on QRT),
cetalfio
I catch your point, but just on some particular case make the difference 1,5°
http://www.rfelements.com/assets/Uploads/DSC35.JPG
http://www.rfelements.com/assets/Uploads/P13.JPG
This will be the answer for the question.
What is really ahead of the others - it has a cage for the routerboard with metal backplate for extra shielding (what you not have when you mount the Basebox to mANT)
Are these available now?
Photo from MUM Venice 2014?
yes, from MUM Venice '14
the 19dB antenna with internal device is just released, and metal CPE case http://www.rfelements.com/en/products/radio-enclosures/stationbox-s/ as well.
I can’t wait for the radio embedded 1foot dish :slight_smile:
I rather use that device instead of Mikrotik’s panel antenna CPE (qrt?) for the following reasons:
  1. first of all, the backside shielding
  2. better sidelobes
  3. i can use 2 radio device inside, with a 2G omni antenna…
(no, it’s still not exists currently)
