Mantbox 15AXs
I have several new Mantbox 15AXs running latest firmware. i have created a simple AP using quick set in 5ghz. i connect one CAP6xlac and works fine. i run a ping to 8.8.8.8 and all good. passes an IP to the cpe and life is good. when i connect a second CPE the Mantbox seems to kill the internet connect on the first CAPXL and the pings stop reaching 8.8.8.8. Anyone else have this? I should add all devices are running same firmware 7.16.1
So Just an FYI i disabled STP on the bridge. Set it to none and it works
