The mantbox_52_15s is intended for point multi point networks.
Can I also use the mantbox_52_15s as wide area access point for mobile devices?
Why not ? “Creating an efficient point-to-multipoint connection used to be tricky, but not anymore: mANTBox 52 15s works well in any setup”
It’s supposed to be designed for any point to multipoint environment. I will give it a try.
“You can’t go wrong with the mANTBox 52 15s – it is fast, powerful and easy to use in any P2MP setup!”
Hi normis,
could you inform if mantbox_52_15s will be suited for use in a wide area as access point for mobile devices?
or someone from Mikrotik.
I’m not from Mikrotik, but I have tried a mANTBox 19s and I could get a good signal on my phone 1000 feet (300m) away in a forested area, so expect that or better if you’re using the 52 15s in a clear area.
Hi Cablenut9,
Could you post your wifi settings?
Thank you in advance.
I didn’t see this until now, but I remember which settings I used. Frequency width: 20MHz, Antenna gain: 0 (this is risky!), Channel: 165 (5GHz), Mode: ap bridge, everything else is on default.
this device has 2 concurrent and independent radios ?
or is only 1 radio ?
