Mantbox ac
Hi Guys
Why has Mikrotik decided to discontinue the stable, working mantbox ac for the ax or wifi6 that is not stable or does’nt perform at all as the ac did. I’m at witt’s end and looking for alternatives to replace mikrotik as these ax stuf doe’nt work or perform as good as the older ones did. I hate ubiquity with passion so what do I move to
There’s a lot to choose from if you are not happy with MT product but it’s not right because you are in MT forum, google is the key hahaha just kidding
MantBox ax is just as stable as the older model. Have you used it? If you are facing issues, simply ask here and we can help you solve them. For example, several wireless issues have recently been fixed in 7.19.2
the Ax is not as stable as the older ones. I’ve got 10 ax’s that I had to take down and put it in storage as we’re getting clients disconnecting from the sectors for no reason. If I connect more than 6 clients on the AX the ping just shoot up from sub 1ms to 300ms. If I put the older unit back on the highsite everything is back to normal.
Like I said, make sure you upgrade the software, as most of known issues have been resolved.
