Mantbox ax 15
I facing problem with my two Mantbox ax 15s on wifi 2 to transmit signal 8 km line of sight to SXTsq ax.
Both Mantbox have the came SSID and SXtsq ax same SSID
The country is set to United States.
All is set on default: Tx chain, Tx power, antenna gain, distance, manger, beacon interval, DTIM period, Multicast enhance, QoS classifier.
Is there another configuration I need to do, if yes please help.
From the documentation in regards to distance:
Maximum link distance in kilometers, needs to be set for long-range outdoor links. The value should reflect the distance to the AP or station that is furthest from the device. Unconfigured value allows usage of 2 km links.
Is this wireless network in the United States?
There you go! Default distance is 2km.
