Mantbox AX 15s Configuration Problem
Hello, good evening. I'm having a problem with my Mantbox AX 15s. During configuration, I was advised to update to the latest version. After the update, the Wifi1 and Wifi2 interfaces disappeared. Looking for a solution, I found that the Wifi-qcom driver needed to be installed. Once the driver was installed, the Wifi interfaces reappeared. However, when I tried to configure it for SXT Lite5 stations, only TX appears in the transmissions. Previously, with access points, transmissions were normal, showing both TX and RX signals, but on the Mantbox AX 15s, only TX appears. If you could help me with this problem...
Currently, the RouterOS version is 7.22 with wifi-qcom 7.22.
Not being able to see both TX and RX signals, as well as not being able to see the signal level of the H/V chains, are both limitations of the wifi-qcom driver. I already created a feature request ticket for this a year ago [SUP-190934], but MikroTik closed it as ‘Done’ even though this functionality is still not available.
Thank you for replying to my message. It seems I'll continue to have this problem until someone else develops a solution, because Mikrotik only released the AX version without any supporting functionality. I hope I'm wrong and they're already working on a patch to fix this.
