Hello everyone,
Can you tell me please which model of mikrotik wireless system will be good enough as a CPE for mANTBox ax 15s ?
Hello everyone,
Still need help with that one - but now the question is if Netbox 5 AX https://mikrotik.com/product/netbox_5_ax and https://mikrotik.com/product/MTAD-5G-30D3-PA will be compatible to setup with Mantbox 15s AX where:
Point to multipoint connection.
Can someone confirm if it is possible to set this up with chosen hardware?
The Mantbox 15ax has only 60Deg horizontal radiation pattern. Are your clients situated within 60Deg arc of the AP?
Netbox 5ax + mant30 PA require RF cables between the radio and antenna. These antennas have narrow beamwidth and require careful dish pointing otherwise the performance will be reduced.
Test your path and signal levels on this Mikrotik calculator -
https://mikrotik.com/calculator
