MantBox with sxtq and lhg ac - Bad CCQ
Hi all!
I read several posts on the subject but none with solution apparently.
in several cities and different noise scenarios I see that the MantBox has some problem (we use 15 and 19) With optimal signals (between -50 to -70) we get really low CCQ (5 to 30%) so the throughput is collapses
We use Ap only AC, Nv2, for the moment at 20mhz because the performance is low. Are there ways to improve this?
The channel is at 0% of use and the snooper does not find stations either, so the 5300 channel is good. In 5800 it gets worse.
Any recommendation?
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-onlyac country=argentina \
    default-forwarding=no disabled=no disconnect-timeout=5s frequency=5300 \
    frequency-mode=superchannel hide-ssid=yes mode=ap-bridge nv2-cell-radius=10 \
    nv2-preshared-key=wpm18 radio-name=AP_PM_NORTE security-profile=SEGURIDAD \
    ssid=AP_PM_NORTE tdma-period-size=auto wds-default-bridge=bridge1 wds-mode=\
    dynamic wireless-protocol=nv2
nv2 will return to normal when this is normal traffic
Try to use N/AC band, and CW to 20/40 Mhz… if the radio detect free free air will use 40 Mhz or 20 if it´s noised.
band=5ghz-n/ac channel-width=20/40mhz-Ce \
And mANT must be shielded to better performance, the matterial is plastic type.
Isn’t this your problem?
http://forum.mikrotik.com/t/arm-devices-and-nv2-protocol/120717/1
It is solved in 6.44
Test client to ap bandwith test check it.
I know, does he?
