Where on MT wiki is detalied manual for /file command. I cannot find it.
/file ?
Files can be uploaded to router and downloaded from it using FTP, or sent via e-m
ail attachment. Here a list of all files kept locally on router (such as exported
configuration scripts) can be found.
.. – go up to root
add – Create a new item
edit –
find – Find items by value
get – Gets value of item’s property
print – Print values of item properties
remove – Remove item
set – Change item properties
This should be put into the Wiki with all the other information about RouterOS. Consistency is the key here.
I would email support@mikrotik.com with this issue. They should be able to add it.
There are too many people playing smart, these days…
