Hello
I have some TX power questions.
I have a lot of the old RICs with the RB532 board.
When I have close links, I set TX Power to manual, and experiment with the 3 highest speeds down in 1db steps.
So I get SNR down to about 50db and signal strength around 45dbm.
But now I have set up a p2p link with RIC/522T, and signal strength was way high (short jump).
I set the TX Power to manual and changed the settings, but noting seems to happen…
Then I tried all rates fixed, and that worked.
I have always used the standard wifi cards in these ones (65mw)
But now I have a rather long jump (35km) so I aquired the XR5 cards.
So now I really need answer to these questions…
-What SNR and signal strength do you consider optimal (the one to aim for when adjusting power)?
-Should one use manual TX Power, all rates fixed or any other settings?
-Why didnt I see any change setting manual TX Power on the RIC/522T? -I see some (doing a search on the forum) adjust the XR5 to i.e. 28db TX Power in winbox, but some say there is a 10db offset, so when setting it to 18 its really 28 witch is max for the card. What would be the correct settings here?
Best regards
