manualtx power / regulatory domain
sir i am newbie to mikrotik we are using mikrotik for ptp and ptmp we are from india we set the frequnecy mode to regulatory domain and country to india may i know what mode is better for better through put and decrease the latency issue because we facing a very high latency issue from last one month the line of sight is good with signal strenght -50 db and ccq is suddenly falling from 95 to 15 may i know what s the reason
Hello
In the regulatory domain you are using the frequency channels your law permits (it maybe outdated though). The falling of CCQ may be caused by many things like i.e interference, damage or moisture in the cables and connectors, etc etc
What hardware are you using, what is the distance, etc
Have you scanned the usage of channels in your city? Try to change channels at first, then if this doesn’t help, provide more information about your setup
